The Daily CLAD
Community Browser
Re: LabVIEW Symbols: P
SercoSteveB
What does the For Loop 'P' Terminal, identified by the arrow, indicate?
a) That the loop is configured for parallel execution
b) That each iteration of the loop will pause for the duration, in milliseconds, passed to the terminal
c) That the loop is configured to run as a While loop
d) That the loop will pause when the iteration count terminal reaches the value passed to the terminal
Comments
Musale
Answer is A
LordNobady
A
Learning LabVIEW since January 2013
JGmitter
A
nmpundlik
Answer is A.
crossrulz
Knight of NI
A
GCentral
MrStevenUND
A.
RAMESHB
Answer is A.
            More informetion see this link
                               http://zone.ni.com/reference/en-XX/help/371361J-01/glang/for_loop/
2verb
A
adiveppa
Ans is A
jagadishj
Answer is A
sumapatil
Answer is A
SercoSteveB
Answer: A.  Nice one Musale, LordNobady, J-MACK, nmpundlik, crossrulz, MrStevenUND, RAMESHB, 2verb, adiveppa, jagadishj & sumapatil.
Has anyone got a use case for Parallel For Loop execution?
JGmitter
Only use case I can see is performance increases.  I have not used this yet but I probably should be.  See link.
http://www.ni.com/white-paper/9393/en#toc1
crossrulz
Knight of NI
I haven't used them myself, but I hear from some people where they are good for massive computations.  The CLA-R prep material has a question where the computing of FFTs are the best choice for parallelization.
GCentral
LordNobady
as a use case I think some calibration on single array values can be used.
lets say you have an array of collected analog data that to get the correct working value needs some single elements calculations ( lets say an offset and a factor )
by Paralizing you can use all the machine's CPU's to calculate it. ( is mostly interesting with more time consuming actions )
mini09
Agreed A as well... I`m not used parallel for loop...
skian
A
