The Daily CLAD
Community Browser
Re: Interleave Arrays
SercoSteveB
What is Numeric Array Out following execution of the VI?
Comments
crossrulz
Knight of NI
D
Almost had me with the datatypes
GCentral
VenkatStony
Yes Answer: D
If the destination type is unsigned, the resulting value is the least unsigned integer congruent to the source integer (modulo 2^n where n is the number of bits used to represent the unsigned type).
N=32 (It U32)
2^32 = 4294967296
If the output type is integer the Answer is A (-1)
nik35324
D
ReeceTredway
D
Had to look close to set data type correctly back at the empty array
MrStevenUND
D.
SercoSteveB
Answer: D.  Nice one crossrulz (close one), VenkatStony, nik35324, ReeceTredway & MrStevenUND.
Those sneaky little data types
levonsg
D
https://images.youracclaim.com/size/340x340/images/2edb5b1a-9414-44e1-8519-c774fc6dd079/36015_Certificate_Badges_FINAL__1__NI_Instructor_v5.png
NishaV
D
