The Daily CLAD
Community Browser
Re: Interleave 1D Array
SercoSteveB
What are the contents of Numeric Array Out following execution of the VI?
Comments
leahmedwards
I say b). Started an interesting debate with my colleague.
Glad to see you back Steve.
Leah
SercoSteveB
Hi Leah
Thanks, good to be back.
Do you care to expand on the state of the debate?
Steve
crossrulz
Knight of NI
The real question here is does the function use the smallest array size or the largest.  When in doubt, I assume lazy (and test).  So B.
GCentral
alexderjuengere
b
anilktiwari
Answer is B. 0011. Because interleaved function takes the lowest number of elements in participating arrays.
leahmedwards
@SercoSteveB wrote:
Hi Leah
Steve
Hi Steve,
We were debating the same thing as crossrulz: whether it would put extra zeros in when the smaller array ran out, or clip the whole thing it down to the smaller array size. We had to test it to check!
~ Leah
SercoSteveB
Yep smaller array size, the very thing that prompted the question.
I assume lazy as well......oh the nostalgia!!!
rak84
B
Даниилко
Искал способ просить курить, и нашел вот такую штуку
nik35324
B
priya7434
b
Arulmani
Option: B
magic_mike
I think this raises a broader question: do other functions also use the smallest array size? If so then you would be able to answer any similar question. For example, replace "Interleave 1D Array" with the "Add" function and the same thing happens.
crossrulz
Knight of NI
magic_mike,
Generally, yes the smallest array size is used.
GCentral
UMC_Utrecht
I had to look it up again in the help. The resulting array has the size of the smallest size array multiplied by the number of the input arrays. Brrr... You just have to know those kind of detail...
SercoSteveB
Agreed you do need to know that sort of stuff but as this thread highlights assuming the smallest\laziest is a good start point.
abasak86
B.
மணிகண்டபிரபு
B
skian
B
istan0227
B
