The Daily CLAD
Community Browser
Re: Initialise 2D Array
SercoSteveB
What are the contents of Numeric Array Out following execution of the VI?
Comments
PoMu
A. It will have 5 columns since the dimension is 5 and the elements will be from 0 to 4 since the loop executes 5 times and the loop iteration value starts from 0.
nik35324
A
Tsjabrantes
The correct answer is letter A; due to the number of times from the For loop wired in dimension size 0..n-1 terminal of the Initialize Array Function, which It will determine the number of columns of the output (5-1=4 beginning in 0); For loop interaction terminal is going to initialize all elements of the Initialize Array Function counting from 0 till 4 plotted in row.
Smiley Happy
Tarciso Junior
+55 (11) 996-282-103
Skype: Tarciso.junior2
Email: Tsjabrantes@gmail.com
http://br.linkedin.com/pub/tarciso-junior/23/a83/463
crossrulz
Knight of NI
A
GCentral
alexderjuengere
A
Matt-A.
A.
qubirt
A
MrStevenUND
A
CataM
NI Employee (retired)
a)
SercoSteveB
Answer: A.  Nice one all.
Initialize Array creates an n-dimensional array in which every element is initialized to the value of element.
Use the Positioning tool to resize the function and increase the number of dimensions (element, row, column, page, and so on) of the output array. The connector pane displays the default data types for this polymorphic function.
levonsg
A
https://images.youracclaim.com/size/340x340/images/2edb5b1a-9414-44e1-8519-c774fc6dd079/36015_Certificate_Badges_FINAL__1__NI_Instructor_v5.png
