The Daily CLAD
Community Browser
Re: Friday Mind Bender: Array Manipulation!!!!
SercoSteveB
What are the contents of Numeric Array Out following execution of the VI?
Comments
anilktiwari
The answer is D.
abkolhapur
How ?? Clarification required...
SercoSteveB
Hi abkolhapur
This one is supposed to be a bit of fun, the best way to solve it is to work through it with a pen and paper.  It is far to complex for the CLAD, but that is how I roll.
Steve
abkolhapur
Hi SercoSteveB,
Thanks for your suggestion. I tried it and got the result as option D.
Please roll out questions on DAQ.
Thanks In Advance....
Ashwini
crossrulz
Knight of NI
D
GCentral
alexderjuengere
d
I had to look up rotate 1d array ... 😅
AuZn
D
But I cannot find any documentation explaining the behavior of "rotate 1D array" when n is larger than array size.
rak84
D
rak84
Hi AuZn,
n is to assign number of rotation and no relation with array size.
Girogio
Sorry. I don't understand the usage of the index array. It seems that the unique input is the array itself. What is wired on the other inputs?
crossrulz
Knight of NI
Girogio,
The Index Array defaults to increment the index, with the default for the first item being 0.  So it is literally indexing out index 0 through 4 into scalers.
GCentral
Girogio
Very good. Thanks
prathupaapa24
d
AdityaAbhishek
I came across following questions.
Kindly answer it along with detailed explanation.
crossrulz
Knight of NI
AdityaAbhishek,
That is off topic of this board.  These look like CLAD practice questions, so if you have specific questions about these, ask in the Certification board.
GCentral
priya7434
d is the answer.
holiastou
The (d) !
Arulmani
option D
HPravin
Option D
UMC_Utrecht
I was unsure about not connecting the index of the Replace Array Subset, and had to look up in the help.
A.Pratyusha
Really thank you so much. I recently cleared the CLAD certification and more than that I learned many concepts from Daily CLAD which are helping in my daily work.  Even I cleared the Clad, would love to do Daily CLAD questions.
As I'm not sure in which blog that  I can post my thank you note to you, I'm expressing my gratitude here.
SercoSteveB
Hi A.Pratyusha.  Congratulations, nice one!  You can post you CLAD exam experience here.
abasak86
Option D.
skian
D.
istan0227
D
diarmaede
"It is far to complex for the CLAD, but that is how I roll."
Oh thank goodness!!
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
