Consider the example VI shown below. LabVIEW places red coercion dots on block diagram nodes when you connect a wire of one numeric type to a terminal of a different numeric type.
Which of the tables a), b), c) or d) correctly identifies the position of the Coercion Dot on the Add node input terminals for the 4 tests defined in the table below?
NOTE: In the example shown above; Numeric Input 1 Representation is DBL, Numeric Input 2 Representation is U8 and the Add Node Coercion Dot Location is Numeric Input 2 Terminal.
NOTE: Tables a), b), c) and d) contain four entries one for each Test defined in the table above.
a)
b)
c)
d)
