The Daily CLAD
Community Browser
Re: CLAD2017 - It all looks the same: Array 2 of 4
SercoSteveB
What are the contents of Numeric Array Out following execution of the VI?
Comments
GladysToMeetYou
D
Is it just me or did the "Index" and "New Element" input terminal icons change? Is there any reason for this update?
crossrulz
Knight of NI
A
Those functions are Initialize Array and then Delete From Array.
GCentral
GladysToMeetYou
That makes so much more sense. Thank you!
Technoliv
A
Technoliv
A
Vinay_Kumar_M_S
A
nik35324
A
CataM
NI Employee (retired)
a)
Ellie90
a
Matt-A.
A.  Final Answer
qubirt
A
RupaArasavilli
Sir, Can you please tell me how to use windows speech recognition in labview
ravitejashivuni
A
RAVITEJA S
whitecr
a
SercoSteveB
Hi RupaArasavilli
I can't help you, I have no experience of using speech recognition with LabVIEW
Regards
Steve
SercoSteveB
Answer A.  Nice one all.
The icon of the second function narrows down the functionality provided but does not define it.  When I look at the icon it is either Delete From Array or Array Subset. For some reason I tell them apart by the extra output terminal of the Delete From Array which is the deleted portion, not massively intuitive but it has stuck in my mind and I'm happy to run with it.  The length and index input terminals of Delete from Array and Array Subset are also opposite to each other, but that is too annoying to use as an aide memoire.
Vicky17051995
How to drag this to my LabVIEW Block Diagram?
crossrulz
Knight of NI
Download the snippet first and then drag it onto your block diagram.  The snippet was generated with LabVIEW 2014, so you will need 2014 or newer to use the snippet.
GCentral
RupaArasavilli
My data type settings of controls and indicators are disabled. I am unable to change the fixed point configuration. Please help to solve this problem.
Rupa.
rak84
A
istan0227
A
