Consider the Array Palette, shown below and with function names removed and replaced with letters through the power of GIMP. Which of the items on the palette is Index Array?
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
Returns the element or subarray of n-dimension array at index.
When you wire an array to this function, the function resizes automatically to display index inputs for each dimension in the array you wire to n-dimension array. You also can add additional element or subarray terminals by resizing the function. The connector pane displays the default data types for this polymorphic function.
