The Daily CLAD
Community Browser
Re: CLAD2017 - Hardware - DAQmx - What is my Configuration?
SercoSteveB
Consider the VI, which of the following is the configuration of DAQmx Read.vi that would result in the data shown in Waveform Graph?
Comments
crossrulz
Knight of NI
A
GCentral
RayFarmer
Trusted Enthusiast
a)
Regards
Ray Farmer
sankar06
A
Happy to Wire
Baltur
a)
ArAmM
A
CLD
A.Bernau
http://zone.ni.com/reference/en-XX/help/370469AD-01/lvdaqmx/mxread/
As we have an integer input “Samples/Channel” and we would like to read 15 samples per channel answer C and D are no valid answers. So we need the NSamp and NChan in the name of the mode(instance). The difference between answer A and B is the output data type. Answer A  gives a waveform data type and B gives a 2 D Array.
So answer A is the correct answer.
Do I am right that B gives the same DAQ measurement values like answer A just in another data type?
crossrulz
Knight of NI
A.Bernau,
Yes, the sample data is the same.  I personally care about all of the timing parameters, so I almost always use the Waveform type outputs.
GCentral
Tsjabrantes
A...
Smiley Happy
Tarciso Junior
+55 (11) 996-282-103
Skype: Tarciso.junior2
Email: Tsjabrantes@gmail.com
http://br.linkedin.com/pub/tarciso-junior/23/a83/463
sankar06
A
Happy to Wire
Tiger5hark
If we're taking 15 samples at a rate of 1000 samples/s, shouldn't the last data point be located at 0.015s, and not 0.0085s? What am I missing?
crossrulz
Knight of NI
Tiger5hark,
Nice observation.  The last data point should actually be at 14ms (first data point it as time = 0).
Though, it could also be based on the DAQ module used.  It could be that 1kS/s is not possible with the module and the driver rounded the rate to the next highest available rate (~1.65kS/s).  Yet another reason I like to keep with the waveform data type.
GCentral
proph
My thought process: there are 4 plots on the waveform so on the DAQ read, options C and D are no good because they have "Nchan 1 sample" where we clearly need 4 samples. Is that correct?
Between A and B, we want to match the X axis with the appropriate datatype. "time" is for waveform and "samples" for 2D DBL therefore answer is A.
crossrulz
Knight of NI
proph,
Your logic is close.  We have 4 plots.  So that means 4 channels (all work so far).  But we need 15 samples per channel, which eliminates C and D (N Channels, 1 sample).  And then the data type coming out of the function in the code snippet is an array of waveforms, which eliminates B.  That leaves A.
GCentral
proph
What about the comment regarding the label of the axis: Samples vs Time ?
crossrulz
Knight of NI
I think that is true, but would have to verify if the axis name automatically changes.  Though, there are ways to fake the 2D array appear like the waveforms in the graph (set the axis name, apply scaling).  So it is probably safer to look at the actual data type coming out.
GCentral
rak84
A
rak84
To get multiple plot as shown in above question, what modification I have to do in the below attached block diagram
crossrulz
Knight of NI
rak84,
You need to configure your task to have more channels.  Try changing your channel to Dev1/ai0:1.  This will have ai0 and ai1 in your task, which will then show 2 plots in your graph.
GCentral
rak84
Crossrulz,
Thank you very much for your valuable information.
Raajkumar
Please answer this question:
No.of sample per chaneel is :4000
rate:100000
Time target:4
what is answer?
Raajkumar
VI run:4 time in this case what happened?
moni0607
Raajkumar,
1. I am guessing 101 rows and 4000 coulmns
2. i=3, time difference is 1s
moni11
Stop is wired to True constant. that means it will run only once every time you click run. So i (loop iteration) will always be 0. And time indicator value will be the difference between the 2nd iteration and 3rd iteration because of shift register.
istan0227
A
