The negative index will just return the default for the data type (0 for numerics). And it will just increment from there, so the second index will actually be index 0, giving 9.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
Can someone help? This actually looks like the Numeric Value Out is connected to the second row which would make (by default) Index 0, therefore 9. When I connect the Numeric Value Out to the first row (index -1), I get 0 every time, not 9. Please help.
It's all about the index. If you specify an index that is outside of those that are valid for the input array (valid range for the input array in the question is 0 to 5 inclusive). I chose an index of -1 in the question but you would have got 0 returned by Index Array for every index outside of 0 to 5. You get 0 because that is the default value for a numeric in LabVIEW. If LabVIEW can't work out what the value needs to be or you have not specified what the value should be, LabVIEW will use the default value for the data type.
Here are some early The Daily CLAD posts that look at default values (oh the nostalgia)!!
That would be outside of the array range, so you would get the default value, ie 0.
Nope. If the index is outside of the range of the array (negative or greater than the last element's index), you will get the default value.
For this question, -1 was for the first input on the Index Array. But what was actually being used was the second. As you drag the Index Array, each input auto increments from the previous. So with the first being index -1 (which will result in 0), the second will auto-increment to 0 (which will result in the first element in the array).
