The Daily CLAD
Community Browser
CLAD2017 - Fundamentals - Tony what's happening?
SercoSteveB has created the following VI but has poorly commented/documented his work (not for the first time Smiley Wink).  Which of the following most closely matches the functionality provided by the VI?
NOTE: All hidden cases of the Case Structure are shown below:
a) The VI records the average value for each pair of values in Numeric Array In.
b) The VI records the number of occurrences of each unique value in Numeric Array In.
c) The VI records the rolling total of values in Numeric Array In.
d) The VI records the sum of the odd values in Numeric Array In.
Comments
B
Knight of NI
B
I find this easier to do with Variant Attributes
B
Happy to Wire
B
b)
B
crossrulz I find this easier to do with Variant Attributes
Could you post up an example?
Knight of NI
I know there are better examples out there, but this is the first good one I was able to find: https://forums.ni.com/t5/LabVIEW/count-the-number-of-repetitions-of-items/m-p/3367576#M991374
B
B
B
my favorite example is this 2007 nugget:
https://forums.ni.com/t5/LabVIEW/Community-Nugget-3-12-2007-Implementing-sets-with-variant/td-p/4899...
I used this technic in my answear to Re: CLAD2017 - Answer the Requirement - Remove Duplicate Numerics
But I really appreciate the explicite approach, using array functions only
2019 expired compiling executables with LabView 2017
B
Tough one!
