The Daily CLAD
Community Browser
回應: CLAD2017 - Fundamentals - String to Array to String
SercoSteveB
Assuming the whitespace between the words within String Constant are space characters (\s) and the EOLs are \n.
What is spreadsheet string following execution of the VI?
Comments
maccapple
B
crossrulz
Knight of NI
B
GCentral
wayrider
B
Sangameshsh
B like will be shifted by two times
Matt-A.
B
skian
B.
istan0227
B
CA-Pioneer
B.
1) use "spreadsheet string to array" to build 2D array by delimiter character " ", each string is convert to an element in the 2D array;
2) use index array to select the column  = 1 sub array, it is 1D array ('Likes', 'Does', 'Rock's);
3) rotate this 1D array 2 times, it is changed to ('Does', 'Rocks','Likes')
4) use replace subset array to replace the original 2D array (col index = 1) to new rotated array, so ('Likes', 'Does', 'Rock's) -> ('Does', 'Rocks','Likes')
5) join the 2D array back to string by delimiter " ";
