The Daily CLAD
Community Browser
Re: CLAD2017 - Fundamentals - String Manipulation 2 of 5
SercoSteveB
Consider the VIs a, b, c & d (below) each of which generate String Array Out with different content.
Match each String Arrays 1, 2, 3 & 4 with the VI (a, b, c, or d) that generated its content?
Comments
crossrulz
Knight of NI
A - 1
B - 2
C - 4
D - 3
GCentral
Master_Samwise
What is the function being used? It looks similar to a 'Match Pattern' function.
*Edit: it is a Search/Split String function found under Functions Pallet>Programing>Strings>Additional String Functions
nik35324
A 1
B 2
C 4
D 3
nik35324
@Master_Samwise : Search/Split String.
Programming >> String >> Additional String VIs and Functions
abasak86
A - 1
B - 2
C - 4
D - 3.
மணிகண்டபிரபு
A
skian
a) 1
b) 2
c) 4
d) 3
istan0227
A-1
B-2
C-4
D-3
CA-Pioneer
A-1
B-2
C-4
D-3
The key is C answer 4. Because using shift register, the number is set to 2 (Steve) by the search "e" that can not trigger "-1" to stop the loop. Do it will run 3 times and get 3 "St"
