The Daily CLAD
Community Browser
Re: CLAD2017 - Fundamentals - Nested FORs
SercoSteveB
Consider the VI. What are the values of Numeric Value 1 and Numeric Value 2 required to generate the contents of Numeric Array Out shown below?
Comments
DougHarper
C
sankar06
Ans C
Happy to Wire
SPK91
C
ArAmM
C
CLD
Baltur
c)
Intaris
Proven Zealot
Terminal for Numeric Value 2 should be outside the outermost loop, otherwise the output could be neither of the proposed answers......
nik35324
C
crossrulz
Knight of NI
C
GCentral
RayFarmer
Trusted Enthusiast
Answer C
Regards
Ray Farmer
பரத்_குமார்(bharathkumar)
c
Thanks & Regards,
Bharath Kumar
GCentral
SercoSteveB
Hi Intaris
Cryptic....could you expand?
Steve
Intaris
Proven Zealot
If the value of the control "Numeric Value 2" changes between the first and subsequent iterations of the outer loop, any new value of the control can be inferred.  If, after Iteration zero of the outer loop the value of the control would change to 5, the output would be (with a value of "Numeric Value 1" of 3): 0,1,0,1,2,3,4,0,1,2,3,4
Due to the fact the control is read multiple times, race conditions are possible assuming it's not run as a sub-VI.  Nit-picking.
Moushick_kiren
c      3,2
Regards
Moushick kiren M
jwscs
Num1=3 | Num2=2
since only the inner loop appends to the array (in the shift register),
Num2 must be 2 (so 'i' can be 0 and 1).
since we have 3 times of 0,1 in the output array, the outer loop must execute 3 times,
thus Num1 must be 3.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
A.Bernau
obviously not A and not D.
The Array is written by the inner Loop so we get the pattern 0, 1, 0, 1, 0, 1 if we have Nummeric value 2 = 2
So answer C
SUYAM
Ans C
Murali_Chennai
Answer is:C C.JPG
Muralidharan Dasarathan
Tsjabrantes
Answer C...
Smiley Very Happy
Tarciso Junior
+55 (11) 996-282-103
Skype: Tarciso.junior2
Email: Tsjabrantes@gmail.com
http://br.linkedin.com/pub/tarciso-junior/23/a83/463
KinWahSoo
My answer is C
The 0 and 1 values are responsible by the inner loop (Numeric Value 2) while the repetition of  0 and 1 value is responsible by outer loop (Numeric Value 1).
To obtain 0 and 1 value, 2 iterations are required. Therefore, Numeric Value 2 should be 2.
Meanwhile, to obtain 3 repetitions of 0 and 1 values, 3 iterations are required on the outer loop (Numeric Value 1)
Therefore,
Numeric value 1 = 2
Numeric value 2 = 3
Best Regards,
Soo Kin Wah
Technical Support Engineer
NI
Saterneon
The answer is C😇
blink247
answer is C.
If you just look closely all you need is 0 and 1 in the for loop inside so, you only need 2 loops in order to get that.
second, look at the output, there are 6 cells which requires you to have 3 loops on the bigger for loop 🙂
WAVE FROM PH
AFox83
C
rak84
c
wayrider
C
abasak86
C.
skian
C
istan0227
C
aaabbc
Prepare the program that creates 4 random integers between 1 and 6 different from each other, saves them in a sequence, and calculates the arithmetic mean of the numbers in the sequence.
