The Daily CLAD
Community Browser
Re: CLAD2017 - Fundamentals - FileIO - Read Data File
SercoSteveB
Assuming the File Path for each VI points at DataFile.txt and that the format of the DataFile.txt is as shown below.  Match each VI to the corresponding Numeric Array Out?
1)
Comments
keshavboss
1.B
2.C
3.A
4.D
crossrulz
Knight of NI
1B
2C
3A
4D
GCentral
nik35324
1B, 2C, 3A, 4D
Murali_Chennai
@SercoSteveB Ans:
1.B
2.C
3.A
4.D
Muralidharan Dasarathan
A.Bernau
For me it was the most time consuming D-CLAD for the last months, so I had to change from a “help file based” approach to a “real coding with LabViEW” Approach:
1-b         I guess the function Read Delimited Spreadsheet was designed for such purposes. So no further explanation necessary.
2-c          Important is, the Read File function reads the whole content of the file in the first Iteration and returns an empty string in the second iteration. The carriage return Linefeed symbol located in the lower right corner means “Convert End of Line” and NOT Read “line wise” as I thought first. For the output, only the second iteration is relevant. So the output array should be empty.
3-a         During the last iteration once again we read an empty string. With this output tunnel only answer A) makes sense.
4-d         Because Steve printed an D close to the output 😉
