The Daily CLAD
Community Browser
Rif.: CLAD2017 - Fundamentals - File IO: 1 of 5
SercoSteveB
What is the value of String Length Out following execution of the VI?
NOTE:  Assume a Windows system and that no errors are generated by the VI?
a) 0
b) 17
c) 18
d) 19
Comments
crossrulz
Knight of NI
A
GCentral
Vinay_Kumar_M_S
A
File pointer needs to be set to start of file to read
mini09
A
A_rid
A
nik35324
A
AlexBY
Hi guys,
I'm new and it's the first time I write, so excuse me for my english.
I  don't understand because the Read from Text File function returns
an empty string if I don't set to start of file to read (I suppose with Set File Position function).
Since count is -1, it should return all the string as output;
obviously I'm wrong, but why?
crossrulz
Knight of NI
When you tell the Read From Text File to read a count of -1, it will read all of the data starting at the current file pointer.  In this case, the file pointer is at the end of the file due to the Write To Text File moving the file pointer as it writes.
GCentral
AlexBY
All right, I looked for it in the LaVIEW Help, but I didn't find anything about the pointer.
Thank you
qubirt
A
Matt-A.
A.
SercoSteveB
Answer: A.  Nice one all.
This question is a little bit mean Smiley Indifferent, but an important aspect of file access.
AlexBY makes a good point, the impact of File Position is not all that clear in the LabVIEW Help.  These links are a good starting point. Write to Text File, Set File Position, Read from Text File
A.Bernau
A
istan0227
A
