The Daily CLAD
Community Browser
Re: CLAD2017 - Fundamentals - Boolean Value and Value Signaling
The value read from a Boolean Value or Value (Signaling) Property Node, can be of either Boolean or Variant type depending on the configuration of the Boolean Terminal?
a) TRUE
b) FALSE
Comments
TRUE
Trusted Enthusiast
True (except you can not read from a Value (Signaling) Property).
Regards
Ray Farmer
a) TRUE
Variant will happen when a boolean control is set to latching.
True.
Configuring Value (Signaling) Property with latching mechanical action will always returns an error 1193.
Knight of NI
I would say FALSE since the Val(Sig) is a write only property.
Yep, apologies, poorly written question
nice learned something new: TRUE
a) set "latching" operation on a boolean control/indicator will return a Variant via property node (i guess i saw it before but never registered it consciously)
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
