The Daily CLAD
Community Browser
Re: CLAD2017 - Fundamentals - Boolean Value and Value Signaling
SercoSteveB
The value read from a Boolean Value or Value (Signaling) Property Node, can be of either Boolean or Variant type depending on the configuration of the Boolean Terminal?
a) TRUE
b) FALSE
Comments
Moushick_kiren
TRUE
Regards
Moushick kiren M
RayFarmer
Trusted Enthusiast
True (except you can not read from a Value (Signaling) Property).
Regards
Ray Farmer
Baltur
a) TRUE
Variant will happen when a boolean control is set to latching.
nik35324
True.
Configuring Value (Signaling) Property with latching mechanical action will always returns an error 1193.
crossrulz
Knight of NI
I would say FALSE since the Val(Sig) is a write only property.
GCentral
SercoSteveB
Yep, apologies, poorly written question
jwscs
nice learned something new: TRUE
a) set "latching" operation on a boolean control/indicator will return a Variant via property node (i guess i saw it before but never registered it consciously)
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
wayrider
True
abasak86
True.
diarmaede
Using LV2020 or 2018, I get error 1193 when I create a property node to read value and set the mechanical action to latching. Is there a way to set things up so that LabVIEW will read the variant value? Thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
