There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
The Number to Boolean Array function outputs an array of 8, 16, 32, or 64 True or False elements (depending on the numeric representation of the input integer). For simplicity let’s assume a U8 data type. 14 in binary is [00001110], so we get a Boolean array of: [FFFFTTTF]. The 0th element is the least significant bit, which in this case is the false element on the far right.
As this array is auto indexed into the for loop, only values of the iteration count, i, with a corresponding ‘true’ are auto indexed into the output array. As a result the output array has [1,2,3].
The multiply array elements simply multiplies all the elements in an array and as a result, the value of the numeric value out is simply 1*2*3 = 6.
