The Daily CLAD
Community Browser
Rif.: CLAD2017 - Data Manipulation - We are really shifting now
SercoSteveB
Consider the VI, what is Numeric Value Out?
a) Numeric Value Out = ((A+B)-C) << (A+B)
b) Numeric Value Out = (A+B) << ((A+B)-C)
c) Numeric Value Out = ((A+B)-C) >> (A+B)
d) Numeric Value Out = (A+B) >> ((A+B)-C)
Comments
nishith04
b)
Tsjabrantes
Hello everyone!
For this exercise the output result is option B.
The logical shift operation shifts all bits including the sign bit of a signed integer.
Smiley Happy
Tarciso Junior
+55 (11) 996-282-103
Skype: Tarciso.junior2
Email: Tsjabrantes@gmail.com
http://br.linkedin.com/pub/tarciso-junior/23/a83/463
nik35324
B
crossrulz
Knight of NI
B
GCentral
GladysToMeetYou
B
monesh
b)
Ellie90
b
CataM
NI Employee (retired)
b)
Matt-A.
B
qubirt
B
A_rid
Anyone can explain how it works please? Thanks in advance
SercoSteveB
Hi A_rid, check this out.
A_rid
SercoSteveB thank you! But in the event that (A+B)-C is less than zero, the result would it be simbolically the same??
crossrulz
Knight of NI
The same as what?  If (A+B)-C is negative, then we just shift in the other direction.  So it would turn into (A+B) >> C-(A+B).
GCentral
A_rid
Ok now it's clear! Thank you and SercoSteveB!
SercoSteveB
Yep, symbolically the same, but as crossrulz points out we would shift in the other direction.
MAX_2019
B
SercoSteveB
Answer: B.  Nice one all.
The input terminals for this one seem around the wrong way to me, I expect it to be Top Terminal Value << Bottom Terminal Value.  I have to remember to reverse what I think when I use this one.  Ho hum just another thing to remember.
LabVIEW 2017 Help for the Logical Shift function.
Oleksiy7979
LabVIEW 2017 Help for the Logical Shift function does not explain anything to me.  It says:
the function shifts x left y bits (from least significant to most significant bit) and inserts zeros in the low-order bits
But what it really means I have no clue. Too bad that I have no Labview during the preparation, so I can only guess what will be the x << y result. Can anyone explain what happens with the bits in a real life example?
crossrulz
Knight of NI
I will just assume you know what a bit is and that numbers are nothing but a collection of bits.  So what we are doing here is moving the bits in a number.  So let's just say I have an U8 with a value of 10.  We can represent that value in hex (0x0A) or in binary (0b00001010).  The binary view shows the bits nicely.  So now lets shift the bits by 1.  10 << 1 = 20 (0x14, 0b00010100).  Just for fun, let's do a shift of -1. 10 << -1 = 10 >> 1 = 5 (0x05, 0b00000101).
If you still don't understand this, then I highly recommend taking some digital electronics courses.
GCentral
Oleksiy7979
Thank you crossrulz for explanation. I understand now. It is just takes a lot of time for me to understand that 10100 is 20 in binarese language.
istan0227
B
