The Daily CLAD
Community Browser
Rif.: CLAD2017 - DAQmx - Samples per Channel or Number of Samples per Channel
SercoSteveB
Consider the VIs shown below that are functionally identical accept for the values of the constants 'samples per channel' and 'number of samples per channel'.  Which of the following show the contents of VI1 Data Array Size and VI2 Data Array Size following execution of the VIs.
a)
b)
c)
d)
Comments
GladysToMeetYou
A
PakAsia
A.
In VI1 DAQ only wants two samples and in VI2 there are only two samples available.
timmy
Tsjabrantes
Hello guys!
VI_1VI_1VI_2VI_2
So, letter A is the right answer. Smiley Wink
Tarciso Junior
+55 (11) 996-282-103
Skype: Tarciso.junior2
Email: Tsjabrantes@gmail.com
http://br.linkedin.com/pub/tarciso-junior/23/a83/463
crossrulz
Knight of NI
A
First clue is that there are two channels.  Therefore the size of the first dimension will be 2 for both.  A is the only one that works with that requirement.
GCentral
Ellie90
a
A_rid
A
nik35324
A
Matt-A.
A
qubirt
A
CataM
NI Employee (retired)
a)
SercoSteveB
Answer: A.  Nice one all.
Miguel_Reckon
Ninguna de las anteriores! Debido a que no hay ningun ciclo que permita al READ DAQmx adquirir la muestras nuevamente
Al_Niz
@ Miguel_Reckon Translation: "None of the above! Because there is no loop that allows the READ DAQmx to acquire the data again"
No loop is needed to get a 2x2 array because we read 2 channels simultaneously (ai0 and ai1).
arraySize= (number of channels) x (number of samples).
Oleksiy7979
Can somebody explain why we have 2 sample points to read, not 4 from the second VI?
crossrulz
Knight of NI
The DAQmx Timing is setting up the task to be Finite Samples and the number of samples is 2.  So after 2 samples are read, the task will stop.
GCentral
istan0227
A
