Which of the following is/are TRUE regarding the Connector Pane of a VI?
NOTE: Multiple answers may apply.
a) SubVI Connector Pane input terminals can be set to Required, Recommended, or Optional.
b) SubVI Connector Pane output terminals can be set to Required, Recommended, or Optional.
c) SubVI Connector Pane terminals are set to Recommended by default.
d) The default terminal type can be changed to Required in the LabVIEW Tool menu.
e) The default terminal type can be changed to Optional in the LabVIEW Tool menu.
f) Required, Recommended, and Optional Connector Pane terminals are displayed differently in the LabVIEW Context Help window.
g) There is no difference in functionality between Recommended and Optional terminals.
