You are tasked to write a VI that accepts an array of positive numeric values (Data Array In) and outputs an array that contains all of the odd numbers found in the input array (Odd Data Samples Out). Which of the following VIs satisfies those requirements?
NOTE: For all case structures the only case not shown is the Default and in all instances that is wired Array Input Tunnel to Array Output Tunnel as shown:
Have a go at writing a VI yourself or expand the Spoiler tag to see the possible answers.
a)
b)
c)
d)
