The Daily CLAD
Community Browser
Re: CLAD2017 - Answer the Requirement - Remove Duplicate Numerics
SercoSteveB
You are tasked to write a VI?
INPUT(s): 1D Array (Numeric Array In) of I32 numerical values.
OUTPUT(s): 1D Array (Numeric Array Out) of I32 numerical values.
FUNCTION:  The VI must return in Numeric Array Out the contents of Numeric Array In with all duplicate values removed.
Which of the following VI satisfies those requirements?  NOTE:  Multiple answers may apply
Have a go at coding the VI yourself or expand the Spoiler tag to see the possible answers.
Spoiler
a)
b)
c)
d)
Comments
crossrulz
Knight of NI
B, C, D
GCentral
SPK91
B, C, D
vidya1825
B,C,D
P Vidya sankar,
sankar06
B,C,D
Happy to Wire
nik35324
B,C,D
Spoiler
Baltur
B, C and D
alexderjuengere
A.Bernau
Answer A)
1. Sorts the input array. So the order/sequence of the output array is different (wrong)
2. It deletes an element but uses the same index/numeration than before (wrong).
Answer B)
Should be a possible answer.
Running the snippet confirms answer B.
Answer C)
Should work, but I would prefer to use the shift register output.
Running the snippet confirms answer C.
Answer D)
Should work.
So answer b, c, d
mini09
B, C, D
istan0227
BCD
