The Daily CLAD
Community Browser
Re: CLAD2017 - Answer the Requirement - Even Stevens
SercoSteveB
You are tasked to write a VI?
INPUT(s): Numeric an U32 Numerical Value.
OUTPUT(s): Value is Even a Boolean Value.
FUNCTION:  The VI must return TRUE if Numeric is an Even Number.
Have a go at coding the VI yourself or expand the Spoiler Tag to see the possible answers.
Spoiler
a)
b)
c)
d)
Comments
dilipa
a,b & D
sankar06
A,B, & D
Happy to Wire
crossrulz
Knight of NI
A, B, D
From benchmarks I have seen for finding an odd value, B would be the most efficient.
GCentral
N3MRA
I wrote B.  I forgot about the equal to zero block, so I checked the remainder against zero with a constant, but I basically wrote B.
What are the advantages to A or D?  They seem less efficient.
Seth Price, N3MRA
Lab Associate, Chemical Engineering Department - New Mexico Tech
Lab Assistant, Sodium Dynamo Project
crossrulz
Knight of NI
A is the most direct method based on the definition of an even number (divisible by 2).  It is therefore much easier for people to understand.
D has no advantage other than it will produce the right answer.
GCentral
GregSands
For checking for an odd number, the most efficient is probably Rotate Right With Carry - the Least Significant Bit is returned directly.  Of course IsEven is easily computed from this too.  RRWC also has a benefit on an FPGA as it is purely a wiring operation so incurs no clock cycles.
SPK91
a, b & D
mini09
A, B, D
Timsrice
Took GregS's suggestion...
This can almost be done with a single function
But checking if the value is ODD is what this really does, so needs the 'NOT' to go EVEN.
Crossrulz comment about about doing things so that the intention is readable is very important.
Probably all of these would benefit from some comment/explanation alongside them.
levonsg
A, B, D
https://images.youracclaim.com/size/340x340/images/2edb5b1a-9414-44e1-8519-c774fc6dd079/36015_Certificate_Badges_FINAL__1__NI_Instructor_v5.png
kirti3105
A, B and D will give correct output. But A is the simplest and easiest way rather than B and D
Krishna_kp
Hi all,
for zero also these methods will give output as TRUE (even number).
whether zero is an even number?
crossrulz
Knight of NI
Per wikipedia, 0 is even.
GCentral
istan0227
ABD
