12-29-2020 03:10 AM
Dear ALL,
When I use labview API to download files which are at systemlink server, I got the error code 56.
The systemlink version is 19.5. The file size is 23MB.
Anyone know how to fixed this problem.
Solved! Go to Solution.
01-11-2021 05:35 AM
Hi kisyou,
does this error occur for any file being downloaded from the server or only for files of a certain size (timeout error)?
-Stefan
01-11-2021 05:02 PM
Hi kisyou,
From the jpg you attached, it looks like the error message you get is a timeout. How long does it take for the VI to return that error? As Stefan asked, do you get the same error when you request a very small file, say only 20kB or 50kB?
Brad
01-11-2021 07:51 PM
Hi Stefan,
The error is form "http-get vi" . The defaut timeout is 10s. When I modify the defaut value, the problem is solved.
I think the labview vi should be optimesd the systemlink download vi, then we can change it easily.
thanks again
01-11-2021 07:54 PM
Dear Brad,
if the file size is small, the timeout time 10s is enough. The problem is api, we can not change the timeout value by a easily way.
thanks.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
