02-07-2018 12:54 PM - last edited on 03-14-2019 02:18 PM by NIadmin
I have the Systemlink Client installed and it brought with it the nisaltminion and a few other services.
What I have noticed is a situation where the nisaltminion (via python.exe) starts consuming 25% of my total CPU. This caused my battery to die very quickly and I had no idea why.
What seems like every time I put my computer to sleep and wake it up again, it spools up and hangs around 25%. The only thing that works is to stop nisaltminion's service.
Have you seen this in testing before?
02-07-2018 01:07 PM
What version of the SystemLink Client do you have installed?
02-07-2018 02:29 PM
Sorry:
Systemlink client 17.5
Windows 7
Systemlink server "17.5" - I say that because we might have prior-to-release versions kicking around on that server. Honestly could be part of all of my issues.
02-12-2018 10:19 AM
From your description, I'm taking it that all this is happening on a laptop? And am I right in assuming that you don't have any applications running on the laptop that would be publishing information to the server via tags, messages, or files?
02-14-2018 08:39 AM
Do you have DAQmx installed and if so, which version. I vaguely recall that older versions of DAQmx (less than 16.0 perhaps) would trigger a refresh every time SystemLink would try to get information on the hardware. This would result in a bit of an endless loop.
02-15-2018 11:51 AM
Can we look at the salt logs to see if we see any exceptions? The salt minion log is located at "C:\ProgramData\National Instruments\salt\var\log\salt\minion".
02-20-2018 11:36 AM
I have DAQmx 16 installed.
There are a lot of Errors and Exceptions in the Salt logs. I can also email you a link to the log and to the process dump if you would like. I can't put that here.
02-20-2018 02:55 PM
Can you direct message me and send me the logs where you are seeing the errors?
02-20-2018 04:15 PM
Yeah, let me trigger the issue again and I will send you a log with a some-what accurate timestamp.
