09-24-2018 05:13 AM - last edited on 03-14-2019 02:18 PM by NIadmin
When using the API '/nitestmonitor/v1/query-results' function a filter option can be used by adding a JSON format at the 'LabVIEWHTTPclient.vilib:Post.vi' 'buffer' input terminal. Is there more documentation available of the JSON data structure, it is currently not described in the 'Test Monitor Web Service API.pdf'?
09-24-2018 08:01 AM - edited 09-24-2018 08:02 AM
Here is a link to the Swagger documentation for the Test Monitor API.
https://github.com/ni/systemlink-OpenAPI-documents/tree/master/test-monitor
To view the documentation, just paste the yml contents into editor.swagger.io.
09-24-2018 08:25 AM
Hi Joshua,
Thank you for the tip! Very useful, also Swagger was new for me!
Kind regards,
Coert Ansems
