SystemLink Forum
Tags: "Data Type" property node returns error on nested paths
I created two String tags via the SystemLink web interface. The server seems to be happy with them:
From my Client (a separate PC), I tried to discover and read the tags in LabVIEW:
NI Skyline Tag HTTP.lvclass:Query Tags HTTP.vi returned two objects. The "Path" property node gave expected results: ["HelloTag", "Subdir/Tag0"]
However, the "Data Type" property node returned an error when trying to query "Subdir/Tag0":
Error -251909 occurred at NI Skyline Tag HTTP.lvlib:Execute HTTP Verb.vi:7500001
Possible reason(s):
No such tag: Subdir.
Complete call chain:
NI Skyline Tag HTTP.lvlib:Read Tag Settings.vi:200001
NI Skyline Tag HTTP.lvclass:Read Data Type.vi:5400001
Main.vi
Are there certain rules I need to follow when creating tag paths? Or is this a bug?
Certified LabVIEW Developer
(4,148 Views)
We recommend using dot separators instead of slashes.  In general, slashes should work, however I can see how they could mess up the URL routes for the HTTP entry points.
(4,110 Views)
Accepted by topic author JKSH
They only cause a problem when communicating with your server over HTTP. If instead you are using AMQP, the forward slashes don't cause any errors.
Brandon Grey
Certified LabVIEW Architect
(4,105 Views)
We will try to fix this issue in our next update.
(4,097 Views)
Is this recommendation documented somewhere?
From prior experience with the old NI Publish Subscribe Protocol, various operating systems, and the WWW, I automatically think of slashes when I see "path". Other users might do the same.
(4,078 Views)
As of now, it is not documented within SystemLink but as Josh mentioned, we will try to address this in our next update.
Brandon Grey
(4,075 Views)
