‎03-02-2021 10:19 AM
We currently switched our SystemLink server from http to https.
Our test sequence is running great with TestStand and it's communicating with SystemLink without any problems.
When we want to use our LabVIEW user interface we're experiencing some problems, and test results are not recorded by SystemLink.
I saw this message with a basic UI from TestStand examples, what do we miss in the configuration?!
An exception occurred inside the call to .NET member 'BeginExecution':
NationalInstruments.SystemLink.Clients.Core.ApiException: An error occurred while sending the request. ---> System.Net.Http.HttpRequestException: Une erreur s'est produite lors de l'envoi de la demande. ---> System.Net.WebException: La demande a été abandonnée : Impossible de créer un canal sécurisé SSL/TLS.
à System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
à System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
--- Fin de la trace de la pile d'exception interne ---
à System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
à System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
à RestSharp.Portable.HttpClient.Impl.Http.DefaultHttpClient.<SendAsync>d__14.MoveNext()
--- Fin de la trace de la pile à partir de l'emplacement précédent au niveau duquel l'exception a été levée ---
à System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
à RestSharp.Portable.RestClientBase.<ExecuteRequest>d__71.MoveNext()
à RestSharp.Portable.RestClientBase.<Execute>d__58.MoveNext()
à NationalInstruments.SystemLink.Clients.TestMonitor.Swagger.Client.ApiClient.CallApi(String path, Method method, List`1 queryParams, Object postBody, Dictionary`2 headerParams, Dictionary`2 formParams, Dictionary`2 fileParams, Dictionary`2 pathParams, String contentType)
à NationalInstruments.SystemLink.Clients.TestMonitor.Swagger.Api.ResultsApi.CreateResultsV2WithHttpInfo(CreateTestResultsRequest requestBody)
à NationalInstruments.SystemLink.Clients.TestMonitor.Swagger.Api.ResultsApi.CreateResultsV2(CreateTestResultsRequest requestBody)
à NationalInstruments.SystemLink.Clients.TestMonitor.TestDataManager.CreateResult(ResultData resultData)
à NationalInstruments.Skyline.TestMonitorClient.Api.TestMonitorHttpApi.CreateTestResult(ResultCreateRequest request, ResultResponse& createdResult)
à NationalInstruments.Skyline.TestMonitorClient.Api.WeaklyOrderedTestMonitorApi.CreateTestResult(ResultCreateRequest request, ResultResponse& result)
à NationalInstruments.Skyline.TestMonitorClient.Reporter.BeginExecution(String programFile, String loginName, Boolean& errorOccurred, Int32& errorCode, String& errorMessage)
‎03-03-2021 02:02 PM
Are you using a self-signed certificate or a certificate from a certificate authority? Are there any network proxies between the machine running TestStand and SystemLink?
‎03-04-2021 02:45 AM
We're using a certificate from a certification authority.
There's a firewall between the assets and the server and we're able to ask for change on it. I (normally) opened what's ask by SystemLink setup.
‎03-05-2021 01:52 PM
Hi HVW,
Thank you for your response. There is definitely a lot of possible causes for this.
‎03-08-2021 11:29 AM
Hi Mark,
- port 443 is definitely opened, we can have access to the SystemLink server through https.
- the test systems are connected together inside a VLAN, and firewall rules are opened between the VLAN and the server. The VLAN (so the test systems) do not have access to the internet. The server has an access to internet, I guess through a proxy, but we can't modify it and we're not the owner of it.
- good question, I'm a newbie regarding certificates, I ordered a TCID one to switch between http and https. On our corporate network, there's no problem (regarding the https lock inside the navigator). the certification authority is given by our company
I did not think about having a look on the VLAN (technical network) for SystemLink webpage, if I follow you we might have problem also with the check of the certificate through the webpage?
we also saw this possible configuration on the server, could it be related somehow?
‎03-08-2021 11:42 AM
we finally were able to make the test, it seems that the lock is also ok for SystemLink webpage through our VLAN.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
