10-23-2020 04:08 AM
I have SystemLink 2020 R2 (20.1) and SystemLink TDM 20.1 installed.
I uploaded some TDMS files into SystemLink and started the default "FileIndex" DataFinder instance, which indexes the SystemLink File Service. I'm able to perform searches using the Data Navigator web app.
After a while though (about an hour?), I'm no longer able to search:
"Forbidden: EXCEPTION: AoException: AO_ACCESS_DENIED (1): RequestorBase(176): ERROR(181): Permission denied! Failed with error code -65534!"
Restarting the DataFinder instance seems to make the problem go away, but it comes back again after an hour or so.
So far, I've only used a single PC and single user account to use the Data Navigator.
What causes this, and how do I prevent it?
10-23-2020 05:20 AM
Could please check if it also disapears if you close the "FileIndex" Tab in DataNavigator and Reopen it in "Instance Overview".
The answer would help me to analyze.
10-24-2020 03:46 AM
Thanks for following up, Andreas.
I tried to reproduce the issue today but couldn't. Today, I used remote desktop to run Firefox on the server itself as I don't have access to the original test machine over the weekend. I'll try again on Monday and report back.
02-04-2021 08:32 PM
Hi Andreas,
The same error message appeared again today:
I can confirm that closing the equivalent of the "FileIndex" Tab and reopening it in "Instance Overview" makes the error disappear.
