01-13-2021 03:17 AM
I´ve downloaded and installed a testversion of SystemLink successfully on my Win 10 PC.
Due to an error I had to reinstall SystemLink. Now I encounter an error when trying to install SystemLink again, which depends on ni-skyline-rabbitmq-support (20.6.0.49152-0+f0) (see attachement).
I´ve already did try the solution, which is described in the following article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIbbSAE&l=de-DE but I still encounter the same error.
What can I do to install SystemLink again successfully?
Thanks in advanced for your support!
Solved! Go to Solution.
01-14-2021 11:54 AM
Sorry to hear you are having trouble. Some of these instructions will be the same as the document you followed already, but please try the following.
After cleaning everything up, perform the installation again. If the installation still fails please provide me with the MSI logs.
01-15-2021 03:36 AM
Thank you for your support!
I repeated the steps you suggested and noted the following:
All these files/entries didn't exist on my machine:
After cleaning up, i ran again in the same error. You find the generated logfiles attached.
01-19-2021 09:18 AM
Is there an MSI log specific to the ni-skyline-rabbitmq-support installer? Could you attach that log file?
01-20-2021 01:33 AM
Hi Max,
I hope one of the attached files is the right one.
In the Error_logs.png you can see all the created logfiles, which were saved to C:\Users\<Windows Username>\AppData\Local\National Instruments\NI Package Manager\Logs\WinInstMSI
Thanks again for your help!
01-21-2021 07:43 AM
Finally I managed to solve the installation problem by installing Erlang and RabbitMQ manually. Therefore, I executed the following steps:
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
