01-08-2020 02:49 PM
Are there instructions on how to set up systemlink on Microsoft Azure? Like what azure services do I need to purchase? Do I set it up the typical way that I would on a local server once I create a VM? How do I license it? Etc...
Any documentation or help would be greatly appreciated.
01-09-2020 04:16 AM - edited 01-09-2020 04:19 AM
I only experimented with SystemLink on AWS.
For this I setup an AD (cheapest one up to 500 users).
I used the predefined instance for SystemLink offered in the Marketplace, but in hindsight I could've just as easily used selected a custom system.
The rest is installing SystemLink to the VM, setup DNS and configure firewall rules. (The same as would be needed for an on-premise solution)
You might want to make use of the newest feature to move the database to a separate location (additional virtual disk), so data can be managed separate from the installation disk.
https://aws.amazon.com/marketplace/pp/National-Instruments-Corporation-SystemLink/B073PFF3LN
EDIT: Just noticed it can't be bought anymore.
Hope it helps a bit.
01-10-2020 11:13 AM
Thanks for the response Andre.
Yeah I noticed that it couldn't be bought anymore which makes me wonder if it is still supported on AWS and/or Azure. I prefer to go with Azure because that's what my customer already uses for most of their platforms.
Looks like I got some trial and error ahead of me... 😉
02-14-2020 10:53 AM - edited 02-14-2020 10:53 AM
jigg,
We'll be undertaking this same task in the next 4-6 months. I may ping you later to see how you're coming along with this.
02-17-2020 11:06 AM
I got it set up. The only thing I couldn't do yet was get a client to connect and log data. I think that's a port issue but I haven't had time to dig into it too much. I was able to log into the portal remotely which was nice.
A couple tips:
-Make sure you get a VM with enough memory. They say 8G but you'll need more. SystemLink kept crashing with an out of memory error and I had a VM with 8G.
-Azure VMs don't allow chrome and they don't have edge installed. You are stuck with IE which SystemLink doesn't support. I did finally get firefox on there and that seemed to work the best.
Let me know how it goes.
Cheers,
02-19-2020 08:19 PM
Make sure you open the following ports in the Azure firewall. Note opening the ports on the Windows OS side isn't sufficient when hosted in Azure or AWS.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kKHnSAM&l=en-US
03-03-2020 01:46 PM
Did you get this figured out Jiggawax? Very interested in having this hosted in an ITAR cloud service.
