SystemLink
PXIe-5160 NI-DAQmx - creating physical channel - no supported devices found
I use PXie-5160 to measure the Voltage. The self-test and test panel display well, also display well on Windows device manage. But when I use NI-DAQ>>Aquire Signals>>Analog Input>>Voltage, it said no supported devices found.
I am using LabVIEW 2021 version. Could anyone tell me why?
(222 Views)
Accepted by topic author Healthy
The PXIe-5160 is an oscilloscope. It uses the NI-Scope driver softwares not the NI-DAQmx driver software. The NI MAX (Measurement & Automation Explorer) interface is using the NI-Scope software to control the PXIe-5160.
(199 Views)
