SystemLink Forum
OPC UA Connector - Unable to delete monitored tag
I ran into this issue after:
  • Setting up a connection with example OPC UA server from the OPC UA toolkit (not very important)
  • Next morning the example is not running and I wanted to clean up my monitors
  • The screenshot below shows that I can't delete the monitored tag because SL can't connect to the OPC server
I didn't want to delete the OPC server connection, because I might want to re-use it at a later time.
Just for the sake of this report I did remove it and it worked including to dialog that asks to delete associated tags.
SL19.0 - OPC UA Connector - unable to delete monitored tag in case of server disconnection.PNG
André (CLA, CLED)
(2,326 Views)
Hi Andre,
I'll pass this information to our CAR team and see if they have any input on this issue as it does seem to be something that's been overlooked.
If you have any more info on the behaviour then please let me know and I'll add that into the report.
Cheers!
Jacob
Jacob Hopkins | CLD
Technical Support Engineer
(2,255 Views)
Accepted by andre.buurman@carya
Hi André,
We are currently processing this with CAR ID 743604, the target release to fix the bug is 19.6.
Cheers!
Jacob
(2,222 Views)
