09-14-2020 09:06 PM
I installed both the SystemLink server and the client (both the latest versions) on the same computer (Win10), and the following problems occurred while connecting:
"The NI Salt-Minion Service could not be started."
Before the client successfully connected to the server, I tried to remove it from Systems Manager and reset the server. It appeared in the Pending approval list, but still could not connect after passing.The computer firewall is off.
I don't know how to find out what the problem is.
09-15-2020 07:41 AM
If both are installed on the same computer can you try setting the server to "localhost" in the SystemLink Client Configuration utility. "localhost" is special in the fact that it should automatically connect and doesn't require approving it. It also avoid potential firewall issues.
09-15-2020 07:43 AM
If the salt-minion service is crashing you may also want to look at the minion logs under C:\ProgramData\National Instruments\salt\var\log\salt to see if there are any exceptions.
What version of the server and client do you have installed?
09-16-2020 01:27 AM
09-16-2020 06:55 AM
Looks like something corrupted one of your files. I would recommend deleting C:\ProgramData\National Instruments\salt\conf\minion.d\_schedule.conf and then restarting the NI Salt-Minion service from the Windows service manager.
It is a cache file and should automatically be recreated after the service successfully starts up.
09-16-2020 08:53 PM
Thank you very much. We solved the problem with your help
