SystemLink Forum
Message connection closed after 10 minutes inactivity
After testing if it was possible to keep the connection for a message alive and send once in a while a message gave me the following error after pressing the send button.
Error -251232 occurred at NI Skyline Utilities.lvlib:Parse HTTP Error.vi:5080001
Possible reason(s):
Session token '3ca1d12b-951c-4f41-85db-a15b26b672d4' not found.
Complete call chain:
     NI Skyline Utilities.lvlib:Execute HTTP Verb.vi:7500001
     NI Skyline Message HTTP Library.lvlib:Publish.vi:6370001
     NI Skyline Message HTTP.lvclass:Publish.vi:6370001
     SendMessageTest.vi
At first I couldn't figure out why this error was coming up, but I think this happens because the http session times out after 10 minutes. Does anyone know if there is a way to keep the connection alive? or maybe setup systemlink to increase the timeout or disable it.
(1,455 Views)
Accepted by topic author Bas.v.E
In order to keep the session from being cleaned up on the server you will need to periodically send messages even on a dummy/keep-alive topic or do a 0 timeout read on a dummy topic.
(1,419 Views)
