SystemLink Forum
Loading File Viewer and Tag Viewer UI with preset filters
The File Viewer and Tag Viewer support filtering by properties. However, as far as I can tell, the user must manually type in the filter values every time.
Is there a way to load the File Viewer or Tag Viewer web UIs, with filters already in-place? (For example, with a URL query string, perhaps? http://localhost/#fileviewer?Extension=tdms&minionId=cRIO1 )
Certified LabVIEW Developer
(1,477 Views)
Accepted by topic author JKSH
Yes, with the File Viewer when you configure a filter it does change the URL, but they can be very long like below.  Once you have a filter you want you can simply bookmark it with your browser and then use that link to get back to that view at any time.
https://localhost/#fileviewer/filter/propertiesQuery%5B0%5D%5Bkey%5D=minionId&propertiesQuery%5B0%5D...
Unfortunately, this isn't the case for the tag viewer, however you may be able to create a dashboard and use the various tiles to show the tags you use the most often.
(1,440 Views)
You can however easily see the tags for a specific system from the systems detail page via a URL with something like the following.
https://localhost/#systemsmanagement/system/NI_cRIO-9042--SN-01E10AB8--MAC-00-80-2F-24-FB-CE/health
(1,438 Views)
Perfect -- that's exactly what I need, thanks!
I should have noticed the URL change; I saw that the Tag Viewer's filter doesn't change the URL and assumed that the File Viewer behaved the same way.
The long URL isn't an issue as I will programmatically construct the URL query string in my WebVI.
Understood.
How easy or hard would it be for NI to implement a similar system in the Tag Viewer?
(1,430 Views)
