01-27-2021 08:25 PM
The File Viewer and Tag Viewer support filtering by properties. However, as far as I can tell, the user must manually type in the filter values every time.
Is there a way to load the File Viewer or Tag Viewer web UIs, with filters already in-place? (For example, with a URL query string, perhaps? http://localhost/#fileviewer?Extension=tdms&minionId=cRIO1 )
01-28-2021 08:22 AM
Yes, with the File Viewer when you configure a filter it does change the URL, but they can be very long like below. Once you have a filter you want you can simply bookmark it with your browser and then use that link to get back to that view at any time.
Unfortunately, this isn't the case for the tag viewer, however you may be able to create a dashboard and use the various tiles to show the tags you use the most often.
01-28-2021 08:25 AM
You can however easily see the tags for a specific system from the systems detail page via a URL with something like the following.
https://localhost/#systemsmanagement/system/NI_cRIO-9042--SN-01E10AB8--MAC-00-80-2F-24-FB-CE/health
01-28-2021 07:46 PM
Perfect -- that's exactly what I need, thanks!
I should have noticed the URL change; I saw that the Tag Viewer's filter doesn't change the URL and assumed that the File Viewer behaved the same way.
The long URL isn't an issue as I will programmatically construct the URL query string in my WebVI.
Understood.
How easy or hard would it be for NI to implement a similar system in the Tag Viewer?
