01-11-2021 04:29 AM
Thanks, that's a better idea to do it there. I'll just ignore the config tool 😉
01-11-2021 11:08 AM
andre.buurman@carya wrote:
This doesn't require you to install the certificates via the web server config tool.
Note that depending on the clients you use to access the web server, you may need to manually keep C:\ProgramData\National Instruments\Web Server\config\root.cer up to date as well if you aren't going through the NI Web Server configuration utility. It contains the root CA certificate for the SystemLink API, at least the LabVIEW version, to communicate with the server securely, even when using a self-signed certificate.
The configuration utility will attempt to check and synchronize that file each time you launch it, which may interfere with you manually updating it.
01-12-2021 04:21 AM
Hi Paul,
What's the life span of that certificate? Isn't there an automated renewal of that certificate as I can imagine that no sys admin would startup the config util on a regular basis just to update that certificate? Or is that certificate depending on e.g. the LetsEncrypt certificate?
Trying to understand the certifcate update scheme and interdependencies. In my current setup I'm not overwriting the orginal SL certifcates, just pointing the web server to a different set.
01-12-2021 09:07 AM
The root.cer file is the CA certificate from Let's Encrypt, which isn't going to change very often. Specifically, I believe it would be the ISRG Root X1 that you can download from https://letsencrypt.org/certificates/ (pem format).
For maximum compatibility, you'll also want to ensure the certificate file that the web server is using contains the intermediate certificate chain. I'm not familiar with the Let's Encrypt tools to know whether the certificate it gives you already contains the chain or not, but it would be a series of certificates one after the other in the same .cer file. From that same link, I believe that means you would want the Let’s Encrypt R3 certificate appended to yours.
01-13-2022 06:29 AM
Sorry for hijacking a closed thread, Posting it here since my question involves modifying the default webservice conf file.
Q: Is there a way to configure the webservices to verify the client certificate and also to provide the path to the client CA?
I'm trying to do two way SSL / Mutual authentication.
Configuring the HTTP client to authenticate/verify the server is straight forward, On the webservices side we don't have the option to enable the client verification.
niembeddedws.conf file has options to configure the server certs but no options to enable client verification/Client CA to configure.
Any help in this regard is greatly appreciated,
01-13-2022 12:51 PM
Hello, I would suggest a new thread in the LabVIEW forum, particularly because niembeddedws.conf isn't related to SystemLink and actually refers to a different web server technology than the NI Web Server that this thread is referring to. I'm not sure if the web server used by LabVIEW web services can be made to support client authentication.
