01-24-2020 10:54 AM - edited 01-24-2020 10:56 AM
Hi everyone
I'm trying to add systemlink API to my old Labview VIs to save all the result on the Test monitor, but I struggle with two problem.
The property node doesn't have a batch serial number entry,
So I tried using the "Properties" entry with the key "Batch Serial Number" or "nitmBatchSerialNumber" but it doesn't seem to work.
Am I missing something or is it just not supported yet?
I used the VI example on labview "Log Test Result and Test Step.vi" but nothing shows up on the Data viewer (Trend) even though it does appear on the test result
When using teststand i can see the measurement trend
01-24-2020 05:00 PM - edited 01-24-2020 05:27 PM
Hello sklod,
I can confirm that you're not missing anything.
Thanks!
01-28-2020 03:16 AM
Thank you for your answer. I think i'll wait for the next release to implant systemlink to my old labview soft.
For the data viewer, your suggestion works but it's always one data late. The data viewer doesn't update until the next run of my VI. I think i'll wait for the next release as well since i need the batch serial number anyway.
02-14-2020 09:02 AM
Hello again,
Quick status update:
Ryan F
03-06-2020 08:57 AM - edited 03-06-2020 08:58 AM
Thanks for the update.
