SystemLink Forum
Guidelines for speccing a SystemLink Server PC
In general terms, which is more important for SystemLink Server: Raw CPU speed or number of cores?
The system requirements (https://www.ni.com/pdf/manuals/377243l.html ) talks about cores but not CPU speed, so I presume that cores are more important, meaning that a 2 GHz 20-core server would likely be "better" than a 3+ GHz 4-core server from the same Xeon family -- is this a reasonable thought?
For our application, we're looking at 10 nodes with ~500 hundred tags per node. However, the server will also be running SystemLink TDM, and 40% of the tags would be updated at 5 Hz over MQTT.
Certified LabVIEW Developer
(1,972 Views)
Accepted by topic author JKSH
We have lots of micro services that run in parallel for handling multiple tasks, so I would recommend more cores when possible.
If you are using any of our services that index large amounts of data like the TDM or Test Module, I would also recommend plenty of RAM (at least 64GB) and a very fast hard drive.
(1,916 Views)
