01-22-2018 09:30 AM - last edited on 03-14-2019 02:18 PM by NIadmin
Just got a computer as a server and when trying to get systemlink server on it I get an error -2147220309
The description says:
There was a failure while refreshing information about the systems.
The request for discovered systems failed with error code -2147220309
The request for managed systems failed with error code -2147220309.
The request for Jobs failed with error code -2147220309
The request for systems pending approval failed with error code -2147220309
And no devices are discoverable... When I try adding a device manually it says that only NI linux RT systems can be remotely added and the error mentioned above.
Any ideas on how to solve this?
01-22-2018 03:07 PM
Just to be clear, you have a Windows system that you are trying to add to the list of managed systems? What are you doing that gives you the error?
To add windows systems to a SystemLink server, you have to install the SystemLink client on the machine and use the Windows SystemLink client gui to connect the windows system to the SystemLink server. This video shows how.
01-23-2018 01:21 AM - edited 01-23-2018 01:23 AM
I did not explain it good enough, I am having the systemlink server on a windows 10 PC and I am trying to add cRIO 9030s that are connected via VPN.
Whenever I try to update the Systems Manager tab where the managed systems, active jobs are, discover systems and pending approval is.
It also happens whenever I try to add a cRIO manually.
01-25-2018 09:19 AM
I would take a look at the Windows services on your server. Check to make sure that the NI Skyline Service Manager is running. If it is not running, start it manually.
