SystemLink
Can we able to read or write tags if system link cloud license expires
my SystemLink cloud license expired can I able to read or write the tags already existed ?
(2,439 Views)
In what context are you using SystemLink Cloud? Are you able to acquire licensing for it?
Brandon Grey
Certified LabVIEW Architect
(2,413 Views)
i am accessing SystemLink cloud services from the link https://www.systemlinkcloud.com/. I have some build apps that are running in the server. when I open this page normally it is not giving any notification. when I open the web apps it is showing your licence will expire in 2 days. I want to read or write the tags from that page by using myrio for my project. at present I don't want my application to run in webserver. I can run the application using LabVIEW NXG. can I able to read or write the tags?
(2,410 Views)
You mentioned that you're using a myRIO. Are you a student? If so, you should reach out to your university. They most likely have licensing that you could use that would give you access to SystemLink Cloud.
Brandon Grey
(2,403 Views)
Yes, Thank you for your help. I will contact my college for the license. just to know that I am asking weather can I able to read or write the tags already existing if license expires.
(2,400 Views)
Accepted by topic author bhimaabhilash
I don't think it will work once your license expires.
Brandon Grey
(2,397 Views)
yes, i am not able to see my web applications it is asking to activate but my previous application is still running when i open the pervious link. it was displaying what ever I had designed.
Thanks for the help.
(2,385 Views)
