08-24-2022 03:02 PM
Hi There,
I have a remote RT target running linux RT. I am controlling this from a windows host PC running teststand 2019. Both the host PC and RT target are connected to system link. I want to be able to upload a TDMS log file (logged from Veristand on the RT target) to system link. Is there a way to do this using the upload file teststand step for systemlink, on the host PC? I just dont know how to pass the file path to the TDMS file stored on the remote target.
Any help appreciated!
08-29-2022 04:58 PM
Would anyone care to have any input on this one😁
08-30-2022 10:41 AM
08-30-2022 05:25 PM
Hi jdkdev -
My name is Darin, I'm the lead Product Owner for VeriStand. I see two options here:
I hope that helps explain enough so that you can evaluate these two and understand the tradeoffs between each approach. Best of luck and please let us know how you go forward, happy to continue the discussion.
09-12-2022 12:56 PM
So I was trying to access the system link API from the RT controller, however I get the error pasted below stating that the library is not installed. When I try to add the SystemLink Labview API under the software tab of the RT controller (Linux RT System Image 21.5) I don't get any option to install it since it is not listed. The SystemLink Labview API is definitely installed on the host however. So is it possible to install this on the RT controller? Any ideas what I am doing wrong here?
Error -251046 occurred at NI Skyline Configuration Library.lvlib:Open Configuration (Desktop).vi
Possible reason(s):
Unable to load the LabVIEW HTTP client library. Ensure the HTTP Client is installed on the target system.
Complete call chain:
NI Skyline Configuration Library.lvlib:Open Configuration API Key (Desktop).vi
NI Skyline Configuration Library.lvlib:Initialize From Auto Configuration.vi:4270001
NI Skyline Configuration Library.lvlib:Open Default Configuration.vi
NI Skyline Utilities.lvlib:Execute HTTP Verb.vi:7500001
NI Skyline File HTTP Library.lvlib:Get Version.vi
NI Skyline File HTTP Library.lvlib:Send File Core.vi:40001
NI Skyline File HTTP.lvclass:Send File HTTP.vi:5980001
target - single rate.vi
My goal here is to have a custom device just upload a file to system link directly from the RT target.
09-13-2022 07:38 AM
From MAX or SystemLink you need to install the generic HTTP Client with SSL Support for the SL LV API to work on RT.
