SystemLink Forum
SystemLink Error -2147467261
I recently install SystemLink and when I added the SystemLink Test Monitor Client option to result processing, I immediately get the following error running a test sequence. I did verify that the client is connected to the server and in fact the server recognizes that a test is running.
Any help would be greatly appreciated!
Sam
(1,401 Views)
Hello Sam,
Thank you for reporting this issue, we have prioritized a fix for the next release.
The issue is caused by an unsupported data type being logged by the erroring step. As a workaround until the fix is available, you can turn off logging for the errant data object. To do so, go to the step settings panel and deselect the "Log" boolean.
Please reply with any questions or continued errors you find.
Ryan
(1,303 Views)
