SystemLink Forum
NI SystemLink Service Manager Crashes
NI SystemLink Service Manager stops working after a while. In the crashlog_svcmgr, I see two things that stand out.
10/18/2023 09:10:44
NationalInstruments.Skyline.MessageBus.SkylineException: Attempt to publish on a closed channel: SvcMgrReportServicesResponseBroadcast
   at NationalInstruments.Skyline.MessageBus.MessagePublisher.PublishMessage(MessageHeader header, Byte[] body, Boolean mandatory)
   at NationalInstruments.Skyline.AkkaUtilities.SkylineGateway.PublishBroadcast(BroadcastMessage message)
   at NationalInstruments.Skyline.ServiceManager.Internal.ServiceStateTracker.MakeCurrentSnapshot(Boolean updateRemotes)
   at NationalInstruments.Skyline.ServiceManager.Internal.ServiceStateTracker.AddLocalServiceInstance(ServiceInstanceBase instance)
   at NationalInstruments.Skyline.ServiceManager.Internal.MessageManagerBase.SpawnerThreadWithUserData(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
WARNING: exception after exception handler already ran
10/18/2023 09:10:45
NationalInstruments.Skyline.MessageBus.SkylineException: Attempt to publish on a closed channel: TraceLoggerRegisterTracePointRoutedMessage
   at NationalInstruments.Skyline.SkylineUtilities.TraceLogging.ProcessLogger.MakeOrLookupTracePoint(String name)
   at NationalInstruments.Skyline.ServiceManager.Internal.MessageManagerBase..ctor(String moduleName)
   at NationalInstruments.Skyline.ServiceManager.Internal.ServiceLauncher.CreateSkylineLauncher(ServiceLaunchable launchable, Boolean attachOnly)
   at NationalInstruments.Skyline.ServiceManager.Internal.MessageManagerBase.DelayedSpawnerThreadWithUserData(Object state)
10/18/2023 13:09:21
10/18/2023 13:09:22
NationalInstruments.Skyline.MessageBus.SkylineException: Attempt to publish on a closed channel: SvcMgrHeartbeatBroadcast
   at NationalInstruments.Skyline.ServiceManager.Internal.ServiceManagersTracker.SendHeartbeatAndCheckForMissedHeartbeats()
   at NationalInstruments.Skyline.ServiceManager.Internal.ServiceManagersTracker.HeartbeatThreadFunction()
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
Message 1 of 9
(6,177 Views)
Have you checked to see if the system is periodically running out of memory? In addition, is this running on a dedicated server or a personal PC like a laptop?
Message 2 of 9
(6,156 Views)
Also, what version of SystemLink Server do you have installed?
Message 3 of 9
(6,154 Views)
Version 2022 Q1 installed on a Windows Server 2022 with 8 CPU & 20 GB RAM.
Message 4 of 9
(6,144 Views)
After a while, this is what happens and the service stops
Message 5 of 9
(6,139 Views)
If you open the Tags application and look at the history for localhost.Health.Memory.UsePercentage what does it show? If your are periodically getting over 90% and if those spikes align with your crashes then that is the source of your issue and you should upgrade the amount of memory on your server or delete some data.
Message 6 of 9
(6,131 Views)
Thank you for your reply.
We have another server identical to this one, but the product version is different.
It's version 2023 Q3, but we're having problems connecting to the database from Diadem with this version, but we're not having any problems with the service stopping.
We've set up an identical server with version 2022 installed, and this time the connection from Diadem works, but the services stop after a delay.
Regarding verification from Tags, can you tell me how to access this feature?
Message 7 of 9
(6,103 Views)
Should look something like this.
Screenshot 2023-10-19 at 6.51.30 AM.pngScreenshot 2023-10-19 at 6.51.30 AM.png
Message 8 of 9
(6,096 Views)
You will find the photo requested above
Message 9 of 9
(6,090 Views)
