SystemLink Forum
Jupyter extensions are not installable
Hello everyone,
I want to install extensions via Extension Manager in Jupyter but I get following error (seen on Extension_Error.JPG).
When I try to install this extension via console in Jupyter, I get following error (seen on Install_Extension_Via_Console.JPG).
The error says that I need to update Node.JS to a newer version (atleast version 12).
The current version of Node.Js that SystemLink Version 2025 Q1 is using is version 10.16.3, if you are asking for it in command line.
My question is following, how can I can solve this issue? Do I need to update the version of Node.Js? If yes, how can I update the Node.Js version?
It's not working when I use the "nvm install latest" command.
Thank you for all comming replies.
Message 1 of 1
(419 Views)
