Reply
Highlighted
NI TimeSync: FPGA Timekeeper Getting Started
FPGA Timekeeper (Labs):  FPGA Timekeeper 1.1b0.zip
Description:  The FPGA Timekeeper API is a set of VIs that allow you to synchronize absolute time on your FPGA target.  This labs release includes a LVLIB that contains these VIs, as well as several example projects and documentation.
Software Requirements:
The FPGA Timekeeper API requires the following software components:
  • LabVIEW 2010 or later
  • LabVIEW 2010 FPGA Module or later
The FPGA Timekeeper examples also require the following additional software components:
  • LabVIEW 2010 Real-Time Module or alter
  • NI-RIO 12.0
Installation Instructions:
  1. Download and unzip FPGA Timekeeper 1.1b0.zip
  2. Open FPGA Timekeeper.lvlib
You can browse the example projects to see examples of how to use the FPGA Timekeeper. There is also additional help found under the Documentation folder in the unzipped location.
Jeremy L.
(22,558 Views)
Re: NI TimeSync: FPGA Timekeeper Getting Started
What is output by the FPGA Timekeeper.lvlib:Get Time.vi if the unit is indoors and never sees a PPS signal?
Ryan Vallieu
Senior Systems Analyst II
NASA Ames Research Center
(3,401 Views)
Ryan,
I'm sorry your question was not answered before now. If the Timekeeper is never synchronized to a source, it will simply return the time in ns since the VI started. (It's basically just a counter that starts at 0 and counts upwards).
Ty Prather
Technical Marketing Specialist
(3,038 Views)
Rif.: NI TimeSync: FPGA Timekeeper Getting Started
What are the measurement units of "UTC offset" property and "offset from time reference" from FPGA Timekeeper.lvlib:Get Status.vi?
(2,503 Views)
Is there any documentation of the algorithm used in the timekeeper VIs? If yes, is it published anywhere or can it be so that it can be referenced?
(1,992 Views)
Hello jtagg82,
As far as I know, there is no public information about the specific algorithm. if you need that information I would recommend contacting customer support, so they can create an escalation with R&D to study the particular scenery and decide what would the most beneficial for both parties. Is important to understand that there are details about what you could expect from the algorithm, that in most cases should be enough to cover your documentation requirements. I am aware that some very specific applications require having the algorithm specific information, but it would require an investigation. I handle a similar case a few years ago, if you want more details, please send me a private message.
Randy @Rscd27@
(1,930 Views)
Reply
