06-09-2006 11:41 PM
06-12-2006 11:03 AM
Hi 还是秘密,
I believe your image is correct. Verify your procedure with the one below. Also, you can reference the attached image.
In Switch Executive, click on the Hardwires/Buses tab.
Add a Bus.
Highlight your first IVI Switch and check Connect to Bus.
Select a Base Channel of r0 and an End Channel of r7.
Highlight your second IVI Switch and check Connect to Bus.
Buses are a group of hardwires. For more information, please reference the NI Switch Executive Help. The topics of interest can be found by expanding the following:
NI Switch Executive Help>>Configuration>>In MAX>>Hardwires/Buses Tab
To summarize that information, you want to use buses to quickly create a group of hardwires together and associate them with a single alias name. Buses are particularly helpful when hardwires are used for column or row expansion in a matrix where a series of channels are connected to another series of channels. So, in your case, a bus may be easier to create as an alternative to 8 hardwires.
Let me know if you have further questions!
Chad Erickson
Switch Product Support Engineer
NI - USA
